305 TBI stock engine harness for 350 TPI?
Old Dec 17, 2022 | 03:35 PM
3rdgenjohnny's Avatar
Car: 2 1992 Camaro RS
Engine: 305/350
Hello I’m new to this group. I have a 1992 RS 25th anniversary with a 305 TBI with a T5 5 speed. I am doing a 350 LT1 swap from a 1995 firebird. Can I use the stock harness from the 305 that’s in the car now? The motor should make about 550whp when done I have a P1S procharger for it. Don’t really want to go aftermarket ECU like Holley ECU as the pockets aren’t that deep. Thank you. Of if you guys know another stock harness replacement any from from the 5-$700 range if the stock harness cannot be used.
Old Dec 24, 2022 | 01:50 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: 305 TBI stock engine harness for 350 TPI?
Nope. Too many differences in sensors, and number of fuel injectors.
Old Dec 24, 2022 | 02:31 PM
ULTM8Z's Avatar
Plus you have the optispark on the LT1 vs. HEI on the current engine.
Probably better to get an actual LT1 harness to do the swap.
Old Dec 24, 2022 | 04:20 PM
stew'86MCSS396's Avatar
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Initial thoughts was to the subject, TPI it can be done but after reading the body of the message, LT1 any thing is possible. The LT1 PCM connectors are different as well and that would be a boat load of splices to switch it over not to mention adding the extra wires for the ones absent from the TBI harness.
Old Dec 24, 2022 | 08:08 PM
vorteciroc's Avatar
Top Answer: 1
I would suggest purchasing a used LT1 (Gen-II SBC) Engine Harness (from a Camaro or Firebird) from EBAY.
It will work in conjunction with some of the Original wiring, but mostly from the C100 Connector.
iroc the 88
May 14, 2009 01:23 PM
Moonlight
Jan 29, 2009 08:41 AM
Donald1992
Jan 17, 2008 11:53 PM
Axoid
Oct 24, 2003 11:33 PM
Josh91Bird
Mar 22, 2002 02:34 PM
