Do I need wiring harness?
Old Mar 23, 2023 | 08:36 PM
dylan0503's Avatar
Car: 1987 Firebird Formula
Engine: 305 Carbureted
I’m about to pull a Vortec 350 from a junkyard truck to replace my 5.0. Do I need the wiring harness from the Vortec or will it work with my stock one from my carbed 5.0?
Old Mar 23, 2023 | 09:14 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: Do I need wiring harness?
Depends on what you are doing with it. If you want to retain the vortec fuel injection system from the vehicle you pulled it from, probably. If you are just going to run a carb your existing wiring harness should be fine.
Old Mar 23, 2023 | 09:20 PM
dylan0503's Avatar
Cool, I’m sticking with the carb so good news for me
Old Mar 23, 2023 | 09:59 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
You probably want the connectors that go to the alternator but there's not much of the harness you're going to need for a carb conversion.
3WRBOOO
Jun 18, 2004 10:58 PM
