ECU QUESTION
Old Apr 27, 2023 | 06:57 PM
19eighty4_z28's Avatar
Car: One Chevy built in the 80s
Engine: 5.7 crate
Axle/Gears: Quick performance 9” 3.70
ECU QUESTION
I am about to have my 5.0L HO swapped out with a newly built 350…by an engine shop. Does the stock ECU have any purpose once that happens? Besides engine parameters does it control anything else the car does? any help appreciated
Old Apr 30, 2023 | 06:14 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: ECU QUESTION
depends on what was swapped out. You can remove the 305 and put a 350 in using absolutely everything the 305 was using. The ecm is controlling timing advance, a bit of fuel mixture with the carb and torque converter lock up if you have an automatic transmission.
Old Apr 30, 2023 | 08:40 AM
Re: ECU QUESTION
Zackly: you can swap out the castings to anything you want, but if you retain the factory carb and distributor, you'll need the ECM and all the sensors and whatnot. For example, I ran mine (83 L69) on a 400 for years.
If you change to a non-factory carb, you'll also have to change to a distributor with vacuum advance. This is NOT optional. The original dist WILL NOT work right.
goalieforlife
Jan 29, 2007 07:05 PM
PhLaXuS
Jul 16, 2005 10:16 PM
flippinTHEbird
Oct 18, 2002 01:56 AM
91TA
Aftermarket Product Review
Sep 13, 2001 10:08 PM
