JKT/UKT suffix code??
Old Sep 1, 2023 | 05:48 PM
danderson's Avatar
Not sure if I'm just crazy or something ... But I can't seem to find the suffix code for the small block that's in my '91. Long story sorta shortened, a/c bypass pulley didn't fit and pulley was significantly larger than the one on the compressor. Compressor part number didn't match GM numbers for '91 Camaro, but cross referenced to truck, so decided to check suffix codes. After getting it cleaned up a bit, I could make out V0224JKT or UKT, but I don't see these codes on any lists. Also couldn't make out any VIN stamp, event after trying to clean it up a bit more. What are your guy's thoughts, or do you see something else that makes more sense? Thanks!
Camas_Camaros
Feb 14, 2009 06:44 PM
SS Ball3r
Jan 18, 2007 05:16 PM
cheese_kake
Sep 2, 2005 08:47 PM
cfabe
Jan 7, 2002 11:00 PM
