305 Identification
Old Sep 21, 2023 | 01:59 PM
dogdaddy123's Avatar
305 Identification
I am not sure if this is the right place to ask this, but I just purchased a project vehicle and it appears to have a old 305 in it, previous owner was unaware of the origin of this vehicles engine so I thought I would try here. It looks like it has a casting number of 140 0202, but I can’t find any info that relates to it… I am attaching a picture also to see if you guys might have any insight, thanks
Old Sep 22, 2023 | 07:58 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 305 Identification
the traces of blue paint would indicate a 1977-82 engine-305 engines came out in 1976,LH dipstick through '79.RH after. most 305s 8.5 C/R but certain ones-;81 and later were 9.5
Old Sep 22, 2023 | 08:43 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Mortec.com is the best resource for casting numbers there is.
Old Sep 23, 2023 | 12:29 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My 10/82 built 1983 G20 had black paint over blue paint from GM.
The Suffix code behind the water pump should give more info on what it came from the factory as.
Old Sep 24, 2023 | 09:42 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
I have seen some late build '82s with the black blocks. Did the van have the 9,5 305 like some 1/2 ton 305 pickups had ?(with ESC)
Old Sep 24, 2023 | 06:17 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
14010202 = 80-85 305
Old Sep 24, 2023 | 07:52 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
It did, flat tops and 601 heads on it, esc but no feedback carb and OE tubular manifolds and catless true duals.
sam816
Feb 9, 2023 06:02 PM
Tim Newton
Jan 16, 2023 11:58 PM
Jeremy Brown
Aug 3, 2020 11:33 AM
Buzzliteyear
May 31, 2020 11:37 AM
z28boy88
Jan 21, 2007 06:06 PM
