305 or 350?
Old Jan 17, 2007 | 08:49 PM
z28boy88's Avatar
Car: 1983 Camaro Z28
Engine: 305 V8
305 or 350?
this might sound kind of stupid but i dont have a clue if my engines a 305 or a 350 i ve had people tell me both, its suppose to be a 305, but iv heard thta its not the original engine that came in my car and that its a 50, the block color is orange, but i belive it was painted when it was rebuilt, the car is a 1983 chevy camaro z28. is there any differnces that i could see that would tell me the difference in a 305 and a 50 so i know what engine my car has in it, its suppose to be a 305. Is there a differece in starter size betwen the engine or anything, thanks
Old Jan 19, 2007 | 10:51 AM
Vader's Avatar
They are externally identical. Since the engine was cleaned and painted, it should be easier to read the casting numbers on the left rear ledge of the block:
Check the numbers at www.mortec.com and you'll find out exactly what you have.
Old Jan 19, 2007 | 06:51 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
If the motor is original it is a 305.
Now to know for sure you need to do what vader said and look at the casting numbers that are on the bellhousing flange. Find the numbers and I will look them up for you.
Old Jan 19, 2007 | 07:59 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
numbers. we need numbers, no one here can help you at all without numbers
get them posted here and then we can help you
otherwise all we can do is speculate and waste our time doing so
Old Jan 21, 2007 | 02:16 PM
z28boy88's Avatar
Engine: 305 V8
ok
ok ill look at the block number and post it on here, shulda done it the first time sry
Old Jan 21, 2007 | 05:48 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
assuming the block hasn't been decked you can look for a pad under the alternator and get the number off that.
Old Jan 21, 2007 | 06:06 PM
z28boy88's Avatar
Engine: 305 V8
there is a number on the pad behind the alternator the # is 11191c
firstfirebird's Avatar
I'm having a case of deja-vu...
https://www.thirdgen.org/forums/faq-board/209426-305-350-a.html
Does anybody search before posting anymore?
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
