LS3 swap trouble codes
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i read this in the description for the l3s e-rod:
can anyone explain this? thnx
- The specially calibrated engine controller does not engage a number of features associated with production-model systems, which eliminates the possibility of trouble codes. It also has an SES (service engine soon) LED indicator embedded in the fuse box.
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: LS3 swap trouble codes
I believe what they're saying is they have programmed out monitoring of some circuits. For instance, they are probably not running evap system checks, so there will be no potential for P0442, 446, 496, etc
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
kool, so i can use a scan tool if i ever have codes to read
Car: '90 RS
Engine: 377 LSX
Tec21-CamaroLover
May 8, 2001 08:49 AM
