84 Trans am engine swap , 84 corvette 350
Old Jul 23, 2025 | 08:32 PM
  #51
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: 84 Trans am engine swap , 84 corvette 350
IDK....really hard to tell in the vid. Anyone else seeing #3 intake barely opening?
I'd measure the lift on that one IIWM. I'd expect to see ~.420"...ish.
Old Jul 23, 2025 | 10:34 PM
  #52
MadAtComputer's Avatar
Car: 1984 Trans Am
Engine: 84 corvette 5.7
Axle/Gears: OEM. Disk, LSD, 3:73
My dad is going to see if a friend of his that builds engines will check it out. We don't have the tools to measure it.
In the meantime I'm going to work on sorting out the brakes since I already have the line/hoses.
Update. My Dad's friend is going to help me out in a couple of weeks.
Been too hot and humid to do much. I went though my wiring diagrams again and found the oem choke power wire, tested it and hooked it up. I had been using a temporary wire that I disconnected whenever I was not running the car. When I have a day that is not in the 80s-90s with 90+% humidity I'll work on the brake lines and hoses.
Chuck84TA
Jul 2, 2013 03:52 PM
kmcn47
May 16, 2013 03:08 AM
tylerv350
Aug 31, 2010 08:52 PM
johnnyboy0274
Oct 3, 2009 05:27 PM
vasquezmrysvll
Apr 9, 2008 04:23 PM
