Air cleaner help/swap
Old Jan 18, 2024 | 10:23 PM
19eighty4_z28's Avatar
Car: One Chevy built in the 80s
Engine: 5.7 crate
Axle/Gears: Quick performance 9” 3.70
forgive me here but the 350 I’m swapping in my 84 Z28 has an open style air cleaner. Would it be possible to reinstall the factory dual snorkle set up the 305 came with? Or is that too restrictive? Probably asking why I want to consider that, I dunno to preserve some of the OE look I guess. Holley 650 carb on the new motor if that means anything. Open to other ideas as well but that new air cleaner is UGLY!
Old Jan 19, 2024 | 08:33 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Air cleaner help/swap
How much power will the new mill make? There are tradeoffs for both. With the open element you get plenty of air, but it is hot air. The snorkel assures cooler air, but maybe slightly restricted. If the new motor doesn't make that much more power, the dual snorkel system is probably fine. You can also use your butt dyno to feel if there is a difference.
Old Jan 19, 2024 | 10:11 AM
VIZ28's Avatar
Car: 1989 RU7 1LE / 1997 RS
Engine: 305 TPI / 3800 Series III
Transmission: T5 / T5
Axle/Gears: 3.45 / 3.23
Considering the air cleaner on an original LT1 (350 with 6,500 rpm redline and 780 cfm carb) was more restrictive than the HO set up, you will be fine, and getting cooler air.
Old Jan 19, 2024 | 12:31 PM
Depends on the carb.
If it's yerbasic 4150 or 4160 like a 1850, or a 3310, or an actual high-perf one, it won't fit. It'll hit all sorts of parts of the top of the carb. However if it's a 4165 or 4175 (spreadbore) such as a 6210, then yes it will. Can't tell in the photo.
Old Jan 19, 2024 | 05:11 PM
Engine: 5.7 crate
probably in the vicinity of 350hp, so about triple what it had stock. I’m not a fan of open cleaners like that so if I can ditch it I will. I can’t find what type of Holley it comes with. Crate motor from Chevy. 350/347 turn key if that helps
Old Jan 19, 2024 | 09:30 PM
https://www.thirdgen.org/forums/atta...carb-list-.jpg
Ante84
Carburetors
Mar 1, 2020 12:34 PM
'84Z28
Carburetors
Jan 19, 2013 06:34 AM
82chevyz284bbl
Feb 27, 2010 11:31 PM
Ghigman3
May 8, 2003 10:57 PM
jfox55
Jul 22, 2002 02:11 PM
