Camshaft Break-In
Subscribe
Jun 26, 2024 | 12:04 PM
Replaced the camshaft on my 383 Stroker. Wondering if its a good Ideas to use the Royal Purple Break-in oil plus Comp Cam Break-in Additive? Any Suggestions?
Reply 0
Jun 26, 2024 | 12:27 PM
Re: Camshaft Break-In
Quote: Replaced the camshaft on my 383 Stroker. Wondering if its a good Ideas to use the Royal Purple Break-in oil plus Comp Cam Break-in Additive? Any Suggestions?
Is it a roller?
Reply 0
Jun 26, 2024 | 04:08 PM
If you are installing a roller lifter cam then cam break in is not required because the lifters 'roll' over the lobes whereas a flat tappet cam slides up the cam lobe, thus needed extra lube and 20-30 minutes of high/ variable engine speeds so cam does not get scored from the lifter. Always put extra lube on ANY new cam for aid in allowing the cam and lifter surfaces to mate together.Do Not let the engine idle below 2000 RPM for at least 20 minutes. Preferably longer. So yes to both lube additives.
Reply 0
Jun 27, 2024 | 06:20 AM
What does the cam manufacturer recommend?
Reply 0
Jun 27, 2024 | 12:44 PM
No. Flat Tappet.
Reply 0
Jun 28, 2024 | 09:29 AM
Quote: No. Flat Tappet.
Follow the manufacture instructions carefully and hope it does not go flat.
Reply 0
Jun 28, 2024 | 08:41 PM
Read this from another thread: https://www.thirdgen.org/forums/tech...ml#post6151319
Reply 0
Subscribe
