Would this be a good cam for my tpi 383?
Old Jun 7, 2005 | 07:45 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Im putting togeather a 383 the rotating assembly is comming here is the cam that was recommended to me.
comp cams 08-501-8
212 218@50 488 495
the guy i was on the phone with was kind of short and didnt have the time to explane this stuff to me. Can anyone help me out with some of the numbers.
Old Jun 7, 2005 | 08:16 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
We have a guy in our 3rd Gen club who dyno'd 442RWTQ and 389RWHP with a ZZ4 cam in his 383. It is a slightly smaller cam than the one you posted.
He is about ready to run at the track and with that kind of power we are talking a 11 second car if he can hook it. If it was me I would be looking at something in the 218 to 224 degree range on the intake side.
Old Jun 7, 2005 | 09:30 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
It all depends on what you want out of the car. If you want ballz to the wall performance, than that is a small cam for a 383. A friend of mine installed a new cam in his 383 over the winter and ran a best of 11.90 this past saturday. It's in the 240 range with lifts in the low 500's.
Old Jun 7, 2005 | 10:11 PM
91RS5speed's Avatar
Car: 91 RS
Well im looking for somthing i can drive everyday and will pass the sniffer. Do you think the zz4 cam would be a better choice? Or am I asking to much to make a 383 pass emmisions and should i go with a 350?
Old Jun 7, 2005 | 10:14 PM
Car: 1989 GTA
Engine: 369 TPI
IMHO the one Comp Cams recomended would be better than the ZZ4 for the 383. It would idle very nicely. I was using it as an example of a build up here locally.
Old Jun 7, 2005 | 10:20 PM
91Z28-350's Avatar
ZZ4 cam in a 383? Yuck! That's even smaller than the XR264HR-12 you listed. Go for the XR276HR-12 or the XR276HR-14 (custom on a 114 LSA for less overlap). The bigger the engine the bigger the cam you can get to pass smog. With a 383 you'll likely need a custom grind anyway, for a small base circle...unless you're going to double check the clearances and grind whatever you need to?
If the XR276HR (08-503-8) is too much for you or you feel uneasy about it go for the XR269HR. BTW, this is exactly what 1989GTATransAm recommended that you look for 218 (XR269HR) 224 (XR276HR) intake duration.
Personally, I'd go for the XR276HR ground on a 114 LSA. I believe that can pass CA smog in a 383 (not a 350).
Old Jun 10, 2005 | 10:09 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
HI 91RS5SPD, what a small world.I live in duluth also,and am also building a 383 for my 91-Z28. Also contacted comp and got about the same spec, but used a 112 lsa +4 with almost the same lift. I am getting a set of AFRs also and am going to use a stealth ram. I would like to hook up and see your header install that was one of the things i have been thinking about. please e-mail me asap at fluidmotion1@earthlink.net .Also who do you use for machine work and are you going to assemble your own engine.THANKS
Old Jun 10, 2005 | 11:07 PM
Evil 88IROCZ's Avatar
Car: 88 IROC
Engine: 305 tpi
Transmission: 5 speed
To properly judge the cam in your engine more information is needed. What heads are you using? What compression are you running? What is your rear gear? What idle vaccum can you live with? The number one reason for lack of power is improperly matched parts.
Old Jun 11, 2005 | 12:11 PM
91RS5speed's Avatar
Car: 91 RS
Sure ZEEYAA im at work today but maybe sunday? Ill send u my cell or somthing when i get home. Ill also send u the name and number of the mashine shop.
What are you doing about the emmisions and stealth ram. Cause the intake is not emmisions leagal.
well its gona be a 383 9.8:1 cr 180cc heads slp runner ported intake, headers and full exhaust, 3.08 posi and manual trans.
Old Jun 11, 2005 | 12:46 PM
91Z28-350's Avatar
Take the recommendation from Comp Cams with a grain of salt. FWIW, I called last week for ****s and giggles, they recommended the same cam to me on my 350, with stock heads, intake, and full exhaust. Most of the time they just go by the "description" in their catalog and make their recommendation.
Old Jun 11, 2005 | 05:56 PM
ZEEYAA's Avatar
Car: 1991 Z-28
HI i was also not overly impressed with comps tech guy he was very short and to the point and did not ask me alot of information that i knew he needed, I guess they were just buisey but when your going to make a major decision and spend 800/1000 bucks on a roller set up you would think they would hire some help that would be a littel more attentive. But in the same breath I also met in person one of the guys at SOUTHERN NATIONALS and he was a great guy. I wish i had gotten his number so i could have called him direct. Anyway yes please do e-mail me at my address and give me your number I will be around most of the day sunday. THANKS.........
Old Jun 11, 2005 | 07:07 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i am using a comp cam 112 lsa .503/.510 lift in my 383. it was going to go into my 350 until i deceided to build the 383.
Old Jun 11, 2005 | 09:01 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I am going to be running a 383 with 10:1 compression, Comp 218/224 cam with 112 LSA on .480 lift and HSR system. The guy told me a 224/230 cam so I went one step below for daily driven reasons. I have 3.73's and full exhaust.
Old Jun 12, 2005 | 06:25 AM
CAH383's Avatar
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
My 383 loves the LPE 74219. 219/219 .560/.560 with 1.6 rockers. Great idle as well.
Old Jun 22, 2005 | 06:46 PM
BrandenCali's Avatar
With a 383 it seems to be very important the whole build sheet needs to match well with the whole combonation.. They say with a 383 it's best not to over size the cam.. Let the Ci's make the power with the proper combonation.. So basical the zz4 passes well with Ca emisions as it did for me with the Vortec's.. I yet to use any 1.6 rockers to see what diffrences they will make for the zz4 but probably not enough.. Im leaning toward the direction of a zz9 on 1.5- 1.6's.. The cam should stay streetable and pass emissions.. It's just further researching is that the better cam for the combonation or not..
Old Jun 22, 2005 | 07:41 PM
Mark 89Formula's Avatar
Don't bother changing a ZZ4 cam to a ZZ9. They're very similar.
https://www.thirdgen.org/techbb2/sho...hreadid=304998
A newer design from Comp, Crane, or Crower would be a better replacement for a ZZ4.
Old Jun 22, 2005 | 09:49 PM
I think I viewed that information recently.. Very interesting.. So that is around the actual specs of zz9's coming from tpis? what about Gm, same thing?
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
camaro71633
Sep 1, 2015 10:24 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
