1990 TPI LS Swap tach & speedo
Old Aug 20, 2024 | 08:00 AM
eduardosac's Avatar
Car: 1990 Iroc-z
Engine: LS3/LSA blower
Can someone please point me in the right direction, I've spent a 3 days trying to search how to get the speedometer and tachometer to work with my swap. The car is a 1990 TPI IROCZ, which now has been swapped with 5.3L T56 ..I have the Dakota Digital SGI-100BT, all i can find is information for people that have the vss buffer box, that states to tie into the k pin which I don't have.Please someone help me out
Old Aug 20, 2024 | 08:21 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1990 TPI LS Swap tach & speedo
Pin D at c207, grey wire. The ecm was the Vss buffer
https://berlinetta.info/C207.htm
Old Aug 20, 2024 | 08:24 AM
Engine: Lb9
Transmission: M20
https://austinthirdgen.org/storage/d...ter_pinout.jpg
Old Aug 24, 2024 | 04:57 PM
eduardosac's Avatar
Car: 1990 Iroc-z
Attempted to wire it up the tachometer directly to the back of the wiring of the cluster with no luck, used pin 7 passenger side..I even changed the the signals to the sgi from input 4cyl to output 8cyl
Old Aug 26, 2024 | 01:48 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
https://www.dakotadigital.com/pdf/SGI-100BT.pdf
hope this helps a little, I have not done it myself yet but will be doing it soon, the sgi-100BT PDF covers all the different scenarios - I beleive Page 8 covers the setup for our speedos APPLICATION #3 (H-L) (someone correct me if I'm wrong)
http://www.skulte.com/T56.html' The f-body T56 has a 17 pulse per driveshaft revolution VSS signal generator in the tailshaft. This has to get converted to a 4000 (or 2000) pulse per mile signal for your VSS buffer input. dakota box is spliced in between the transmission and chassis wiring.'
topher01
Apr 6, 2015 06:15 AM
zacharyhorn
Nov 15, 2007 03:24 PM
drain89
Feb 5, 2004 09:49 AM
Camaro91S
Jun 13, 2003 10:13 PM
sbrice18fan
May 14, 2002 02:07 PM
