383 SBC stroker
Car: 1986 iroc Camaro
Transmission: Manual TKX
Axle/Gears: 370
383 SBC stroker
Hi guys, I need some advice on this build. I’m currently putting a 383 Stroker in my 86 iroc the block is a 1 piece rear main seal . Can someone tell me if there’s a difference between the flywheel for a one piece and two piece main seal ??? Thanks
Re: 383 SBC stroker
Your 86 motor should have been a 1-pc. Therefore you should be able to use your existing flywheel, subject to balance issues. Which are entirely dependent on how the 383 is built.
Jfinnkma91
Sep 30, 2012 09:06 PM
