383 one peice rear seal balance question
Old Sep 30, 2012 | 03:54 PM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
I'm building a 383 from a 1 peice rear main seal 350 block. I know with a 2 peice it can be internally balanced, people are telling me that a 1 peice it can only he externally balanced?
So if I go to the machine shop to balance my rotating assembly, will I still need a weighted flexplate and damper?
Old Sep 30, 2012 | 06:21 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 383 one peice rear seal balance question
Not really a engine swap question (given you already asked the same in the correct dept)
https://www.thirdgen.org/forums/tech...eice-rear.html
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
cRoe4
Aug 7, 2015 08:46 PM
