V6 EFI - Carb 1st gen 350 swap
Old Oct 1, 2024 | 09:10 AM
MaazInfinite6's Avatar
I got a 1986 2.8 v6 700r4 firebird.
I am halfway through a computerless carb 350 swap (Pulled out of a 73 monte carlo), I have the engine in, mounted, and rad connected. I also got a v8 700r4, which is bolted and mounted.
Question is, will my dash work? I understand that theres no computer, and that the interior info lights wont work, but I want its core functions like the spedo/tach and basic info like oil pressure and temp to work. Would I be able to just yank a harness (firewall beyond) and connect it to my interior harness?
Last edited by MaazInfinite6; Oct 1, 2024 at 04:58 PM. Reason: Forgot to mention something
Old Oct 1, 2024 | 09:17 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: V6 EFI - Carb 1st gen 350 swap
If it was working with the V-6, it will work with the V-8 except for the tach. You need a V-8 tach. You don't need to yank any harness except for the ECM harness...
Old Oct 1, 2024 | 09:22 AM
Im fine if the tach doesnt work on the dash, would I be able to jsut get an auxilary tach?
Old Oct 3, 2024 | 12:07 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You could but I would just get the factory one working and modify it for a V8
Gus68
Apr 10, 2012 09:05 PM
creepingdeath
Sep 13, 2005 08:26 PM
CaddiBird
Apr 30, 2003 05:41 PM
Berlinetta
Mar 8, 2002 11:50 PM
