880 vortec block info
HI
i have a vortec 880 block 4 bolt main that has had sum issues
cam and piston
whot id like to know is
are the con rods on the vortec 880 block of set
can these rods be used with non ofset pistons
the machine shop fited my rods with a set of silvoline 1436 pistons
from the info i have found these are for a 1969/70 chevy
not a 1998 880 vortec !
is this corect ? ive tried to find a answer nothing !
just a simple yes or no !
thanks
cam and piston
thanks
Re: 880 vortec block info
350 pistons are 350 pistons. All pistons fit all blocks, in the same overbore. It's a small block Chevy after all. Year of the block doesn't matter. All the same from 67 - 200x, subject to the usual dish, dome, etc. kind of stuff. Which, since some years some motors came with flat-tops and other years others dished in various amounts and so on, the "catalog listing" might well list one style as "stock" for some years butt not others. Doesn't matter. All pistons fit all blocks and can be chosen for reasons other than whether they fit or not.
Not sure about "of set". If you mean "offset", then it doesn't matter, as far as fitment. Stock rods aren't "offset" in any case; that's a property of pistons, wherein they shift the pin over to the side slightly in the direction of rotation to reduce side loading. All 350 pistons fit all 350 rods fit all 350 blocks fit all 350 cranks in that regard. Cranks & blocks of course have their own year break from 85 to 86 butt that doesn't affect pistons or rods.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
iirc the 880 originally had metric rings . But doesn’t matter with an earlier pistons. The fit a 5.7 Length rod. . It’s not a stroker so the pistons work. Thread
