LS1 Alternator close to Engine Mount Bolt
Old Mar 5, 2025 | 09:41 PM
John Shield's Avatar
My stock LS1 alternator is 3/16 inch from the driver side engine mount bolt. Is this too close? I had another alternator that fit without this issue but it was slightly larger and was getting caught by the steering rack on right hand turn? Is this far away enough? Maybe an insulator and cutting down that stud a bit might help? I'd appreciate your input.
Old Mar 8, 2025 | 11:54 PM
Re: LS1 Alternator close to Engine Mount Bolt
In case someone reads this, I ended up grabbing a grade 8 nut and leaving it on when I cut about 3/16 off with a cut off wheel. I then tapered it a bit and then ran the nut up and down the stud a few times. I ended up with about 3/8 of a gap between the two where I put a terminal boot on. Seems "good enough".
Old Mar 12, 2025 | 04:12 AM
DKAuto's Avatar
Car: 1985 Firebird SE
Engine: Gen V LT1
Transmission: 8l90
I may be wrong but I believe you can unbolt the stud from the alternator housing and use a bolt with a nut as a stopper for the base making it closer to the alternator housing and allowing more clearance.
kaka
Jan 10, 2018 12:16 PM
SiCkRs
LSX and LTX Parts
Dec 12, 2016 10:38 AM
ShMaCk2004
May 12, 2011 09:06 PM
firebirdjosh
Sep 11, 2005 05:49 PM
itsjustabird
Dec 10, 2004 05:41 PM
