Engine Removal 1984 Trans AM
Old Mar 15, 2025 | 10:45 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Sometime this year I will be removing the 305 (with A/T) in my car to replace rear main seal and to clean & paint the engine.
Since it is a T/A with the ground effects about the car, do i have to remove the front ground effects so that the engine hoist will slide under?
I have to remove the air deflector below the rad.
I have removed engines in a-body gm cars in the past.
Suggestions?
Old Mar 15, 2025 | 10:52 AM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: Engine Removal 1984 Trans AM
I had to come in from the side on mine, otherwise I would have had to remove the front bumper.
I have this engine hoist, which was the longest one HF sells.
https://www.harborfreight.com/2-ton-...ane-58755.html
I didn't have to remove any ground effects.
Old Mar 15, 2025 | 11:53 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Why don't you simply raise the front of the car? Don't you have to do that any way to get motor mounts, tq converter bolts, etc,?
PETERK
Apr 25, 2012 04:00 PM
peterc005
Dec 1, 2011 04:55 PM
trueburton
May 7, 2004 09:53 PM
ERIC'86IROC
Feb 5, 2001 05:57 PM
