Will it fit?
Old May 20, 2025 | 08:17 PM
Vhanta97's Avatar
Car: 1984 Camaro Berlinetta Starship Ed.
Engine: Worn out SBC 305 5.0L V8
Axle/Gears: Stock
Will it fit?
So I'm pulling a 350 out of a 94 suburban 1500 and would like to use the same accessory brackets that it came with to help keep the engine management easy to handle. However I'm worried that the factory mount brackets will be too tall for the hood to close. Does anyone know if it'll fit or should I just find a serpentine bracket system to buy?
Old May 21, 2025 | 09:36 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: Will it fit?
Those brackets are too tall. You will need to find a set of F body brackets.
Fermin91rs305
May 28, 2012 06:12 PM
westman
May 2, 2005 03:10 PM
86 sc
Aug 22, 2002 11:12 PM
sprayed 88
Feb 12, 2002 05:22 AM
