305 carbureted into a V6 car… wiring?
Old Apr 30, 2026 | 06:50 PM
AGELE55's Avatar
This is a 92 project car that was originally a V6. It came to us with a 305 sitting in the hole but not set up to run.
We got the 305 running with a remote starter setup. Now it’s time to sort out the wire harness. We are not sure if this is the V6 harness, or if the PO included a 305 harness. We have a number of mystery connectors, ring terminals, and fusible links to figure out.
Question 1- With the harness roughly laid in, it appears there are fusible links with large ring terminals grouped together ending up near the starter. I assume these go to the BAT terminal. Along with the fusible links is a large purple wire that the PO cut off. This appears to be our start voltage to the solenoid…correct?
Question 2- Further down the harness there is a branch with an additional three smaller ring terminals, two of which have fusible links. Any clue where there are supposed to go?
Boobie
Jul 14, 2022 09:31 AM
Gizmoz28
Oct 26, 2020 06:54 PM
l84fi
Apr 22, 2010 08:38 PM
themodifier
Feb 21, 2003 05:11 PM
