Engine Swap in a berlinetta?
Old Jan 28, 2002 | 09:27 AM
MaroonBerlinetta's Avatar
Car: 1984 Pontiac Firebird
Engine: 307ci V-8
How complicated would it be to swap a stock v-6 with a police intercepter 305?
Old Jan 28, 2002 | 01:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Quite, actually. Typically makes more sense economically to sell the V6 car and buy a factory V8 car, even with a bad engine. The V6 car has to have a lot of sentimental value (like being your first car or one purchased new by your family) to make to worthwhile.
The best approach if you go ahead with the swap is to get a donor factory V8 car (close to or same year & model as yours) to get all the parts you'll need - transmission, mounts, springs, accessories, radiator, harnesses, ECM, exhaust, tach, etc., etc., etc. Set the two cars side-by-side, take pictures of both before starting to disassemble, label everything on both cars as you take them apart.
The engine mounts on the frame are easiest to move while the a-arms are off, which you have to remove to switch the springs, but that's easiest to do with the weight of the engine to help compress the spring - a Catch-22 that's an example of the obstacles you will encounter.
It can be done (obviously), but don't expect it to pay off financially.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
