Motor swap bolt sizes FYI....
Old Jan 30, 2002 | 08:07 AM
Big Money Mike's Avatar
Im getting ready to put my 305 in the car this weekend (finally!!!), and I needed bellhousing bolts, pressure plate bolts, and motor mount bolts... I couldnt find them anywhere including Summit and Jegs, so I went to the Pontiac dealer and found the sizes. So just to be a nice guy, and possibly help others with a swap, I thought Id list the bolt sizes for future reference to others:
Bellhousing bolts (T5): .375X16X1
Pressure Plate: M8X1.25X21.6
Motor Mount (the 2 long ones that bolt the engine to the mount): 7/16X14X5 1/8
The bellhousing and pressure plate bolts are standard bolts that you can get at a hardware store. The motor mount bolts seem to be a special automotive bolt and are available through the dealer for $2.71 a piece.
Old Jan 30, 2002 | 09:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pressure plate bolts are not standard bolts!!!! They are Grade 8, and they have a shoulder behind the threads to "dowel pin" the clutch to the flywheel in the exact right place. If you use regular bolts you will have a vibration problem and a safety risk that is IMHO unacceptable. Also, they are 3/8"-16 (at least on 2-piece RMS flywheels), and are available from Mr Gasket, ARP, and a host of other specialty mfrs.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
Elliswon
Aug 10, 2015 12:33 PM
