Lt1 heads on older block
Old Jan 30, 2002 | 11:30 AM
Ray Burrows's Avatar
Any one with ideas about using Lt1 heads on an older 350 short block. Some one has said there is a water passage problem, but was not specific about that area. I am condidering a pair of heads and the Lt1 intake as a combo, so the intake matching is not a problem. Thought or comments????
Old Jan 30, 2002 | 12:00 PM
mat89RS's Avatar
with over 2000 hour of machine work it might be possible but I doubt ...the thing is with those engines, the waterpump has a reverse flow ...then, there's a steam line in the back of these heads and and the manifold for an LT1 is dry ....so I don't know how you'll figure out to make this combo work.
I
Good luck to you !
Old Jan 30, 2002 | 05:52 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
It's possible to modify them to make them work with a lot a machining, but they don't flow well enough to justify the effort or expense. It would be a lot easier to adapt the intake alone. Just my .02.
Old Jan 30, 2002 | 05:56 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I saw an article in chevy high performance a few years ago that told about someone doing that. So it can be done. The main question is why. I have seen whole lt1s for 1200 dollars. It seems like if you want the top end why not get the whole thing.
Just my .02
Kory
Old Jan 30, 2002 | 06:08 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here's the Chevy Mag article
http://www.lt1intake.com/images/LT1-Retrofit1.jpg
http://www.lt1intake.com/images/LT1-Retrofit2.jpg
Old Jan 30, 2002 | 07:43 PM
Tas's Avatar
Tas
What?! Did some body take my scans without asking? That site is down but they have exact same file name as mine
http://members.tripod.com/GRK_Taz/tech/1.html
Old Jan 30, 2002 | 08:06 PM
Thanks John, this gives me the courage to proceed. Saw your article in TPI about Lt1 conversion. Fbird 88---read the article on flow, people have replaced these heads with cheap alum after market and seen very little improvement. Kory---it is the money $1200 for the engine or about $400 for the top 1/2, and the pride involved in doing it. Kory--Maybe we will run into each other being from ***"s country? Thanks again John, I will keep you posted on what happens in '02
Old Jan 31, 2002 | 09:46 PM
Car: 88 Iroc
Transmission: t 56
Ray
What part of wisconsin are you from?
I'm in New Berlin thats a suburb of Milwaukee.
Kory
Old Feb 1, 2002 | 01:02 PM
Engine: 4.0L
I didn't know I had to ask. Sorry.
Old Feb 2, 2002 | 11:40 AM
Tas's Avatar
Tas
its ok, I just felt left out. I showed you and other people that article and that the ports lined up and the intake bolts weren't a big deal and stuff back when the LT1 intake thing started.
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
BBSDesigns
Aug 11, 2015 07:39 PM
