olds 1970 350 big block rocket
Old Feb 1, 2002 | 03:38 PM
korbin's Avatar
ok is this possible to swap into my 1992 firebird ??? i know it won't be direct bolt up....would i need a new rear end or tranny for my car?? right now, it is a stock 305tbi right now.... thanks for ANY help whatsoever
Old Feb 1, 2002 | 06:27 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I think the best answer would be to review the poncho engine swap posts. just relace "pontiac" with "buick", and get a 2004-r tranny prefeably from an 87 & up buick/olds/pontiac.
Old Feb 1, 2002 | 10:21 PM
zerogauge's Avatar
first off, its not a big block. Olds has a 400 and a 455 big block. I believe the 403 is still a small block(could be wrong) 1970 Olds blocks are supposed to be high in nickel content so it will be a pretty solid block for a nice buildup. Keep in mind however that oldsmobile tends to be one of the more expensive motors to rebuild, and performance costs even more. You would probaly be alot better off with a chevy 350 as it is a direct bolt in and all accesories swap over from your tbi 305. You will need all new accesories and/or brackets to make it work. Not sure if the mounting holes would be drilled in the crossmember, but they probaly are. It will be alot of fabrication and I am pretty sure no one makes headers for a olds 350 in a camaro...so it would be alot of guesswork on that department.
Good Luck
Old Feb 2, 2002 | 10:26 AM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
you are correct about the olds engine family-403 is a small block(externally its a low deck)400 /455 are big (tall deck) motors.any swap could be done-but why? specially to a 403. had one in a t.a. put on the 350 rocket heads to get some compression out of it/but that also downsized the valve size(s) cant recall, too.flaws i can remember when futzing around with it-its weak internally-"windowed"main bearing support/h.volume oil pump put all the oil in the valve covers-need to run a stock or hi-pressure pump-check out joe mondello's site-olds guru.somethig funky with the balance too, i think. swapped in a 4 speed and had to do some dancing with the balance shop to get it smooth. zgauge is right sbc is a better choice. my 2 cents:lala: whats up with this happy bast--d funny
Old Feb 2, 2002 | 12:23 PM
korbin's Avatar
ok the reason is becuz i can get a perfectly good engine for $350.... i have driven the car that it is in and it seems to be a really powerful engine....why oh why...
Old Feb 2, 2002 | 01:29 PM
oh why oh why because if it costs 2k to make it fit and function as intended-(2k is my number/substitute your guess as required)what is benefit of el cheapo initial purchase? buy the 350 and stash it till you can find a cutlass or f85 or an older full frame a body-now you talkin. again my 2 centablos:lala: again with this puffy thing
Old Feb 2, 2002 | 01:45 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
sreZ28
Aug 14, 2015 07:48 PM
