HELP! 305 flywheel won't fit 70's 350 crankshaft..70's 350 flywheel will not fit too?
Old Feb 10, 2002 | 08:46 PM
smoke the tires's Avatar
Hi All-
I was ready to mate the t-5 tranny and my 70's 350 4 bolt main truck motor on my 1986 camaro z-28 (originally w/ a 305), but when I tried to put the 305 flywheel on the crankshaft, it would not slide on the crankshaft and the bolt holes didn't match anyways..So I got my hands on a 70's truck flywheel and it fit but when I tried to put the 86 bellhousing on, it would not fit over the flywheel? What should i do? What is the answer? What flywheel do I need to make this work? Can it be done?
I have searched old posts but nothing...please give me a couple answers...thanks so much..
Dan
Old Feb 10, 2002 | 10:13 PM
thatsme's Avatar
The camaro flywheel is a smaller diameter one than the truck flywheel. In 86 gm changed from a 2 piece rear main seal to a one piece seal. They also changed the bolt patern on the crank for some reason. You need to get your hands on an 82-85 flywheel for the camaro. It's much smaller than the one for the truck. I had the same problem when I tried to swap to the t5 with my 70's motor. I ended up getting a new flywheel from gm for $220. Maybe you'll get lucky and be able to find a used one.
Old Feb 11, 2002 | 07:13 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Look for a 153 tooth flywheel made to fit a two-piece seal crankshaft. Your 305 is probably a 153 tooth flywheel, but is for a one-piece seal crankshaft. While the '70s truck flywheel in correct in that it fits a two-piece seal crankshaft, it is a 164 tooth flywheel (too big). I got a (cast iron) lightweight GM unit for under $170 through Pace Parts.
Old Feb 11, 2002 | 01:28 PM
Damon's Avatar
Be aware of the starter issues that will arise when you slap on a smaller 153 tooth flywheel (even one built for an older 2 piece rear main block) in place of the original 168 tooth one. Obviously the ring gear will be smaller and the starter won't engage it.
I don't know if that's gonna require a different starter, redrilling the starter bolt holes or what but I suspect it's a bigger chore than it looks at first.
Thank *** you can stuff a 168 tooth flexplate inside a 700R4 auto trans. Did this last summer and was afraid it might hit the bellhousing of the slush box but it didn't. Cleared by almost 1/8". Hardly even a challenge.
Old Feb 13, 2002 | 10:05 PM
thatsme's Avatar
When I did my swap. Had to replace the starter. I didn't drill anything and I wouldn't recomend trying
Old Feb 13, 2002 | 10:10 PM
Hey Thatsme-
What starter did you end up using? The one for the 82-85 camaro right? If not which one?
Old Mar 30, 2014 | 10:11 PM
Dave_Kooz's Avatar
Car: 88camaro
Engine: 355
Transmission: T5 manual
Axle/Gears: 3.42's
Re: HELP! 305 flywheel won't fit 70's 350 crankshaft..70's 350 flywheel will not fit
Which starter did u use for the older 350??
Old Mar 31, 2014 | 06:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Holy 12 year old thread, Batman!
Jake_92RS
Jan 28, 2020 10:37 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
justin57
Aug 20, 2015 07:05 PM
st.evel07
Aug 13, 2015 06:15 PM
BBSDesigns
Aug 11, 2015 07:39 PM
