LT1 pulley options??
Old Feb 13, 2002 | 10:47 AM
BigBad75K5's Avatar
Can I use the pulley system from a TPI motor on a LT1 motor?
If not, what are the alternatives to the stock set up?
Thanks,
Chad
Old Feb 13, 2002 | 04:40 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Nope they wont fit, you can use 93-97 f body setup, 92-96 vette setup, and march has 2 setups www.marchperformance.com
Old Feb 13, 2002 | 07:53 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
The '92-'96 corvette setup won't work if you plan on using power steering, just a heads up! I tried but the belt touches the PS box.
Old Feb 14, 2002 | 08:12 AM
BigBad75K5's Avatar
THanks for the info....I checked into the March serp. conversion.
Damn $1000, thats some beer and a stroker kit!!LOL
Old Feb 14, 2002 | 06:19 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
What are you putting the engine into?
Why do you not want to use the stock 4th gen f-body setup ? Its by far the cheapest.
I used the stock 4th gen f-body setup. I dented the crossmember under the ac compressor. Everything worked fine.
I hope this helps.
Kory
Old Feb 15, 2002 | 01:48 PM
BigBad75K5's Avatar
I,m installing it into a 75 4x4 Jimmy.
I bought the motor off a friend when he spun a rod bearing. He bought a used motor and I just paid him the core money to keep it.Thw motor he got did'nt have any of the ***. or brackets on it.
I'm thinking I mite be better off to just put a tpi system on my current 350 and keep the LT1 for anouther project.
The TPI would give me better low end power anyway.
Anyone have a TPI setup for sale?
Thanks for allthe replies,
Chadb
BDR
Nov 7, 2015 03:05 PM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
mygta87
Sep 14, 2015 10:36 PM
L0tuS
Sep 4, 2015 11:16 PM
