TBI to TPI swap
Old Feb 17, 2002 | 10:42 PM
Dean_O's Avatar
TBI to TPI swap
If I buy a 92 Z28 ecu and wiring harness, will it work with a 86 TPI 350. Reason being is becouse I have a 92 RS and am getting ready to do a swap. I figured I could do this and every thing would just change right over. Any tips would be appriciated!
Old Feb 18, 2002 | 01:45 AM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
86 350 TPI, huh? Same thing I'm doing. If you're converting to the '86 engine to speed density here is a list of stuff, some stuff you will defintely need, some are advised:
Dual Fan Set Up (advised imho)
Speed Density ECM #730 (necessary)
Mounting plate for Charcoal Cannister and Air Filter Cannister
Z28 Air Cleaner Boxes and ducting
Speed Density wiring harness (necessary)
TPI fuel pump
IAC Valve, part # 17112193.
Speed Density Knock Sensor, part # 10456549.
TPI throttle cable, part # 10163822.
Purchase (1) Coolant Sensor/MAT Sensor, part # 12146312 (formerly part # 25036979).
SD MEMCAL, part # 16151348.
I think that's about it. Maybe more than you needed. Also, there are other people on here who may say you don't need some of this stuff. I decided to do it anyway.
Good Luck, I think it's gonna be worth it.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
InfinityShade
Aug 22, 2015 08:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
