which one is the knock module
Old Feb 22, 2002 | 05:35 PM
BOTTLEDZ28's Avatar
Transmission: A4
I replace my old 305 with a new 350 and replaced the knock sensor with a 350 but now i have been reading that the "knock module" must be changed too. Where is it. Is it one of the 3 relays on the bracket behind the brake booster on the drivers side firewall. If so which one. I took the bracket off to mount my MSD and the 3 relays are just tucked in under the booster. They all look the same to me. This is for a 91z28 350tpi
Old Feb 25, 2002 | 01:20 PM
Damon's Avatar
You're SOOOOO close! It's not the relays and not square. It is tucked up next to the brake booster right near the relays you are talking about. Sorta flat, weatherpack connector, nothing that would catch your eye.
Old Feb 25, 2002 | 04:50 PM
BOTTLEDZ28's Avatar
Transmission: A4
do all tpi cars have this module? I tried getting one at the parts store and they couldnt find it in the computer. ALl that came up was the sensor/Is this a dealer only item.it is for a 91z28350tpi
Old Feb 25, 2002 | 05:29 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
AC/Delco Part#16128261 if that helps.(for 350)
Bought mine at a dealership.
Cost about $60.
-Rich-
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
