Streetability of Big Block in 3rd gen.
Quite a few people have put a BC in their 3rd gen., but mostly for drag racing purposes.
Are their any BBC 3rd gen.'s out there that are daily drivers?
If so, what's your opinion of the swap? Has handling gone south?
Noise levels? Maintenance access, gas mileage, drivetrain durability (trans life)? Anyone with T56?
Would you do it again, or would you return it to a SBC? I don't want to perform the swap then be sitting with a gass guzzling (< 10 mpg) demon that corners like runaway garbage scow. Thanks!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Only if you use tall valve covers.
My 454SS truck is a daily driver. What difference would it make in a third gen. If you build the engine streetable, there's no real difference in driving. You'll just have a lot more torque available than with a similar SBC.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Streetable? That depends on your definition. I drive mine regularly (40 miles round trip) to work with 3.73 gears. I love it. Runs on 87 octane too. Doesn't corner well though. Would I do it again? Maybe, but the new motor is a big cube small block with an ATI.
More info on the swap is on my page at www.koolmeister.com
Miles
Miles
i run mine all the time on the street in the summer. Corners like crap because of the extra weight and lack of swaybars. RUns slightly hot during the REALLY scorching summer days. Yes it's loud. Bottom line is it's different and a blast to cruise. Nothing like stomping the pedal and peoples jaws drop cause they think you have a 305. The only SEMI complaint i have is that it REALLY guzzles gas. I've had many performance cars, and this one gulps the gas like no other I'm every had. Gotta pay to play I guess. There are only 2 other Camaros like mine in the city and no FIrebirds that i know of. One is a 600+ horse car that might see one night of a cruising a year, and the other is CONSTANTLY broken down. So more or less, I'm the only yahoo out there regularily driving a BBC Third gen. It's nice to be unique
Well, from a HP perspective, that's what I would expect.
Has anyone put a BBC into an IROC or GTA, setup to handle, with stiffer spring rates up front to counter the extra weight, properly valved struts/shocks, and lightweight front-end parts (fiberglass hood, alum. rad., relocatec battery to rear, etc.)?
You can get the handling back to at least stock or better by using lightweight parts like tubular K-member, A-arms, fiberglass, and aluminum engine parts but it will cost a few thousand $ to reallydo it all right. If you add weight in the engine and want to keep your handling you have to take weight off in the area around where you added it. Still, if your after the absolute best handling possible stick with a SBC.
Car: '89 Firebird
Engine: 7.0L
Re: Streetability of Big Block in 3rd gen.
Originally posted by G92Joe
Quite a few people have put a BC in their 3rd gen., but mostly for drag racing purposes. Are their any BBC 3rd gen.'s out there that are daily drivers?
I did a supercharged big block because it's different and gets serious brownie points. If it wasn't for the supercharger I would have chosen a small block. But this way I can drive a mild engine and run 11s in street trim and 10s at the track. Just depends what you want to do.
Now if I can just finish the car so I can drive it!
Quiktrip,
Thanks for the advice. My interest is haviing a BBC installed that would handle as well as or better than a stock IROC (
or GTA).with the proper setup. I guess what I'm hearing is yes, if done properly it could, but no one has yet reported accomplishing this particular swap with attempting to restore any loss in handling ?
Hi guys,
This is my first post ! I have had a BBC in my 1985 IROC since '91 and have it set up to handle. I tried three sets of springs in the car and ended up with mid '80s Heavy Duty S10 Blazer springs. I think the brand was Moog. I also have large adjustable sway bars and sub frame connectors.
Fast355
Dec 2, 2016 06:33 PM
gixxer92
Sep 1, 2015 04:32 PM
