4.3 Liter v-6 in a Bird
Old Feb 25, 2002 | 08:29 PM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
Hey guys i posted this on the v-6 board but thought that this might be a better place. I have a 4.3 liter v-6 out of a 91 s-10 picvk up and i wann put it into the Bird (89 2.8) I wanna know what im gonna need to do this. I already have the engine and it is complete and nto in bad condition. it has a 700r4 attached to it which is the main reason why i bought it i got both for only 120$. If you guys could help me out by tellin me what im gonna need to get this thigninto my car I would appreciate it
Old Feb 26, 2002 | 08:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 4.3 is 3/4 of a 350. From the engine mounts back, they're identical. The front end is the same, just one cylinder's worth farther back.
Basically, you're looking at a V8 swap's-worth of work. Mostly the same stuff needed. Front springs could be an issue, since the 4.3 is heavier than a 2.8, lighter than a V8. It's been done by a few guys (ede, for instance), you'll just have to work through a few issues that us "V6 to V8 guys" didn't.
Old Feb 28, 2002 | 06:15 PM
ede's Avatar
ede
yep i've done it and it's a fair amount more work than a v6 to v 8 swap. the lower motor mounts have to be relocated rearward 3". exhaust is a bit of a problem as well, but nothing that can't be done. if you want to keep ecm controls you'll have the eprom to deal with too.
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
usafirebird
Sep 29, 2015 11:58 PM
