Ford 302
Ford 302
I HAVE A 85 LTD THAT IS JUNK BUT MOTOR IS MINT WITH 2000 ML ON IT I WAS WONDERING IF IT WOULD BE WORTH PUTING IN MY 84 CAMARO WITH NO MOTOR TILL I FINISH MY 454 RACE MOTOR MONEY IS TIGHT AND I WANT TO DRIVE THE CAR
WHAT DO YOU GAYS THINK SHOULD I DO IT
Transmission: 4L80E/4L80E
You can take your tongue out of your cheek now, Bird...
j, there's what "can" be done, and "smart". What you're suggesting is the former but in no way the latter. Sell the LTD, buy a 305 or 350 to put in the Camaro for now; or get a Mustang or Fairmont to put the 302 into. Don't try to 5.0 your f-body that way.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the later 80's crapstains , I believe, had rear sump pans.
This way he can go to ford & chevy shows & watch people scratch thier heads & mutter " WTF?"
Guest
Posts: n/a
Fox body mustangs dont have a rear sump pan, its a dual sump deal. The only difference is the pickup location was changed, so theres a fair amount of messing with it aside of changing the pan. I really dont think the oil pump can easily be relocated from the front of the engine to somewhere else. Probably why Ford left it there.
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
