350-400 swap
350-400 swap
I have a 1987 z-28 with a 350, and i can get a 400 from a friend, my question is will it fit in my car? has anyone dropped a 400 in a f body??
What all needs to be done to get it in and make it fit? and if it will can a 700r4 with a transgo shift kit handle the 400?
Car: 4
Engine: 6
Transmission: 5
Depends on what kind of a 400...
If it's a small blcok Chevy, then yes, it will drop right in. You'll need the flex plate for a 400, it will have the 86-back crank bolt pattern and the correct balance specs for a 400; and the 400 harmonic balancer. Other than that, it's identical on the outside to a 305 or 350.
Those are the illusionall problems that everybodies friend has had, but nobody with the 400 has had, duh! I have had a 400 smallblock for about 10 years and it has been in 4 different vehicles without problem, sadly it has never made its way to the old Camaro. Good luck with the swap!!
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
No you can't put the TPI on the 400 because the 350 is a roller cam engine and the 400 would have to be converted to a roller not that hard. But if the 350 runs good leave it in, if it ain't broke don't bother fixin' it.
Car: 4
Engine: 6
Transmission: 5
There's no reason that you would have to convert the 400 to roller just so you could bolt a TPI induction on top of it. The hardest thing you'd have to do would be to change the angle of the center 2 intake bolts on each side, if you use early-model heads. That isn't specific to a 400 though, you would have to do the same thing with any pre-86 heads. It would be possible to use your L98 heads on a 400 block with the right choice of pistons.
Personally I would not recommend building a TPI 400 regardless, because TPI is so restrictive. On a 350 it already runs out of flow at about 4400 RPM or so; on a 400 it will nose over at even a lower RPM. Basically you will strangle a 400 with a TPI.
I have to agree about the overheating problems... the only people I know of who have cooling problems with 400s seem to be the people who have never had one. I certainly have never had any trouble with any of mine, including the one I had in my 83 for about 12 years (and which will be going back in soon).
Transmission: 4L80E/4L80E
The only cooling problem I had on my 400 was when the lower radiator hose burst. That happened at 210k miles, about 30k of that on that hose; I'd hardly call that a 400 cooling problem.
Sure you can put TPI on a 400. It's called MiniRam...
Car: 86 TRANSAM
Engine: 406
400'S ARE FUN. JUST KNOW WHAT YOU ARE BUILDING AND WHAT YOU EXPECT. YES, YOU DO NOT NEED A ROLLER CAM TO HAVE TPI. IT YOU WANT A ROLLER CAM, THEN ADD THE DOLLARS UP AND FOR THAT MANY BUCKS YOU CAN HAVE A HE** OF A START ON BUYING A MINI RAM. I DONT THINK THE PERFORMANCE GAINS OF A ROLLER ARE WORTH THAT MANY DOLLARS. I DID KEEP THE STOCK TPI ON MY 400, BUT I DONT EXPECT THE ENGINE TO FLY PAST 5000 RPM EITHER. AND I PICKED THE CAM ACCORDINGLY TO MATCH THE REAR GEARS AND WHERE I WANTED THE PERFORMANCE. I SHIFT AT 4500 TOPS, MOST OF THE TIME LESS, AND IT DO JUST FINE. I AM NOT RACING, JUST PLAYING ON THE STREET.
Hello, Michael
Aug 20, 2015 03:19 PM
