Buying an 84 camaro with a 396 in it.
396 Camaro
The first thing that I'd check out would be if the car was a V8 model, then all the wiring should fit.
next thing on your list would be check out what kind of tranny you got under the car, the car you said is an 84 it'll most likely have a 4spd. automatic or the weakly 5spd. standard.
The tranny for a 396 would be the turbo 400 for big HP or the turbo 350 for less HP, my brother had a 73 with a 454 about 400HP and a plain turbo 350 it lasted for years.
Then check the rear end yoyu might need a little steeper gear, maybe a 3.73 or even a4.11.
Then a set of frame connectors would help a great deal.
I'd use some stock exhaust manifolds on it cause, headers will heat soak the starter.
lastly check the motor out compression test, spark plugs, wires, distributer and general engine running.
Send me a message.
Vance
Send me a message.
Vance
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
