305 external ballanced?
Old Mar 18, 2002 | 01:08 PM
GeneralHazzard's Avatar
is the 305 SBC externally balanced? i didnt think it was but a friend who has been workin on cars since the 70's says it is so i wanna know.
Old Mar 18, 2002 | 02:29 PM
Stroked-Z's Avatar
It is internally balanced.
I think the only externally balanced production sb chevy was the 400.
I hope you don't bring your car to your friend to have fixed
Old Mar 18, 2002 | 03:28 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Well, to be technically correct the '55-'85 SBC (except for the 400) were all internally balanced. The '86-'9? were balanced differently than the early SBC, yet similarly to the 400s. Although they are not considered externally balanced because they truely are not, but rather there own type of balancing.
Old Mar 18, 2002 | 05:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Agreed. In a sense, even the '55-'85 SBC's were "externally balanced" in that a counterweight existed on the crank external to the crankcase, but the flywheel/flexplate was "neutral" balanced. In '86, with the one-piece rear main seal, they couldn't have that counterweight there on the crank anymore, so they put the weight on the flywheel/flexplate. The harmonic damper stayed neutral, though, unlike the 400 SBC's.
GouldyGTR
Sep 7, 2015 09:05 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
