What is the most common swap
Old Mar 19, 2002 | 08:45 PM
1stgenracer's Avatar
I am planning on swaping in a V8 in my car soon and i was wondering what was most commonly done and which was the easiest? Like a 350, 383, ect, only carb models because i dont want to have to worry about all that computer stuff.thanks
Old Mar 19, 2002 | 08:58 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
something you wont have to swap again.
in your case, I would find a 350 from an older car with better heads/cam....no smog stuff. or put one together. personally, I like the idea of sticking with a small block to keep the wieght proportional to the rest of the car. make sure your not limiting your engine with external components,match your parts. much info on that stuff here,tech articals,archives.........I've seen it all since '99 ,in here somewhere.
Old Mar 21, 2002 | 12:43 PM
xxwarrior36xx's Avatar
I would have to agree the easiest is to go to a junkyard and pich up an old truck 350 and redo the internals and you good to go. It's cheap and eas to do.
Old Mar 21, 2002 | 09:38 PM
Chronos_Titan's Avatar
If you get an older truck engine just keep the lower end only. The heads they but on the trucks are horrible. See if you can yank some older passenger car heads. The 1.94 i and 1.50 e with 76cc chambers. Then get a performer intake and matching cam and you are good to go. Dont pull apart the bottom end unless it nocks and a valve job on the heads is not the worst idea either.
A 600 cfm Holley and HEI distributor will get you about 270 hp with decent drivability. This is fairly good performer with very little money spent.
Ghettobird52
Jul 5, 2024 11:18 PM
86IROC112
Apr 9, 2016 10:20 PM
Bstrang6
Sep 8, 2015 04:29 PM
SlowAZ28
Aug 31, 2015 07:56 PM
Thornburg
Aug 25, 2015 01:46 AM
