additional parts....
Old Apr 4, 2002 | 04:04 AM
XonyaZ28's Avatar
Alright i am dropping in a carbed 305 into my camaro which was a 2.8 mpfi
noone really explained to me that i would need additonal parts.....
i knew about headers and i was told my v6 5-speed tranny would bolt up but now i am told by someone else that it wont ....
so i am guessing this is what i will need then, can anyone verify or/and add things to this list ?
1989 Camaro RS -2.8 mpfi
-will be carbed-
*Front springs
*v8 headers
*v8 t5 trans
**what else would i need
Old Apr 4, 2002 | 04:32 AM
Tas's Avatar
Tas
people have put the v6's T-5 behind a v8 so you should be able to too. You need the v8 bellhousing and something done to the clutch i forget what exactly. search on this board. Its there somewhere.
Old Apr 4, 2002 | 05:08 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
motor mounts.
adjustable fuel pressure regulator
v8 radiator
V8 Exhaust System
V8 Heater Hoses
V8 Fuel Lines
V8 Gauges
and a friend to yell at
Old Apr 4, 2002 | 06:57 AM
XonyaZ28's Avatar
Originally posted by Riley's35089rs+
motor mounts.
V8 radiator
V8 Exhaust System
V8 Heater Hoses
V8 Fuel Lines
V8 Gauges
alright where can i pick this stuff up at a junk yard maybe ?
and why cant my exhaust system from the v6 work with my v8 engine( cant i just change the headers and be done with it ?)
thanks
Old Apr 4, 2002 | 06:59 AM
XonyaZ28's Avatar
alright i will look into it right now !
thanks Tas
Old Apr 4, 2002 | 11:06 AM
bradkeith's Avatar
On the transmission..I believe that you need a different input shaft to mate up with the v8. I am in no way a tranny expert though. I am in the process of putting a 355 into a 91 camaro of my friends. We changed the mounts, exhaust, gas lines, front brake line on crossmember, interior gauges, We also had to do away with most of the wiring from the 3.1mpfi, and run wires for alt ( your v6 alt won't work unless it is v-belt, or your going to run serpentine. ) they changed the alternator plugs on the newer motors) radiator, run all different hoses for heater and radiator, It sounds like a lot of stuff, but a day at the boneyard and you can scavenge most of it.
Old Apr 5, 2002 | 07:13 AM
XonyaZ28's Avatar
Thanks bradkeith
now i just gotta find a junk yard in dallas
sailtexas186548
Feb 17, 2017 03:07 PM
PurelyPMD
May 5, 2016 04:57 PM
blackz281le
Jan 11, 2016 07:51 AM
Giocio
Oct 1, 2015 12:20 PM
WhteRbt
Sep 21, 2015 09:48 AM
