2.8 mpfi to 5.7 tbi swap
Old Apr 6, 2002 | 12:44 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
Is the dash harness in a 2.8 the same as the one in the 5.0, I droped in a 5.7 and im installing a tbi off a 5.0 with the wireing harness. I am aiming to acheive the engine of a caprice 9C1. I have noticed most of the wires are the same but end up somewhere they wernt before and some of them not the same at all. So I wondered if the dash harness was different.
Old Apr 11, 2002 | 10:34 PM
multi-tasking's Avatar
The 2.8 dash harness does not differ much from 5.7 and 5.0. Ask as specific question and I will try to answer... I can try to answer your question., but there are other much better qualified than myself.. If you are swaping in a 5.7 its a easy (yet tedious) sway.
v/r
m-t
Old Apr 12, 2002 | 07:21 AM
rsc350's Avatar
Car: 92 Camaro RS
Well I hae noticed little things like the wireing for the cruise for instance, it was a wire that just went to my brake switch but now it is controlled by the computer, and I just wondered if everything elce is different that I should know about. Even though I need a whole instrument cluster because the old one was cable driven and now vss.
Old Apr 12, 2002 | 07:02 PM
Re: 2.8 mpfi to 5.7 tbi swap
Wait, I may have spoken to soon.. Which dash harness are you using?
Old Apr 12, 2002 | 07:47 PM
rsc350's Avatar
Car: 92 Camaro RS
The original 89 2.8 camaro harness.
Old Apr 13, 2002 | 05:50 PM
You know I honestly thought we had put transducer(ms) in. But we did not... I am sorry I can't answer your cuise control question right now. The only thing I could do is take the information from books -- sorry...
m-t
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
86Base
Aug 8, 2015 01:34 PM
