European Region For all of our Third Gen brothers and sisters across the pond!
help needed if you can pls
Old Mar 30, 2004 | 12:37 PM
surgeon's Avatar
first off i would like to say hi to you all
ok i have a 1991 rs camaro and live in rushden northants,ive had the car for 3 years now,and have spent a fortune getting it to the state its in now which is the mutts nuts imo
today just got it mot'd got it home,went to take it out for a quick blast and the damn thing wont start
the engine service light stays on,the engine turns but wont fire,and i can smell fuel,i tried to reset the ecm,by disconnecting the battery,but i still have the same problem,service engine light stays on and engine wont fire
if anyone can suggest a solution it would be much appreciated,or do you know of any business or mechanic that could come to me as i cant get the car to them?
thanks to anyone who replies
Old Mar 30, 2004 | 02:41 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Hi Surgeon,
I'm afraid injection is above me at the moment(dirty old carb until the 400ci turbo motor comes together)but you could ask the same question on the TECH/GENERAL ENGINE board.One of the things that board deals with is not starting.By the way what a lucky bugger living so close to the Pod.
350ci shortblock,headers,manifold,engine rebuild kit for sale!!!!
Old Mar 30, 2004 | 02:52 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Welcome aboard!
I trust you tried the usual stuff, like checking for a spark, and anything blocking the flow of air to the intake? I would be more inclined to say ignition, since you say it doesn't fire, which I presume to mean it cranks with absolutely no firing at all. If there was a spark AND fuel in the chamber, there would at least be a stumble.
Si
Old Mar 30, 2004 | 04:03 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Since the engine service light comes on and stays on, it should have a trouble code stored in the computer. Have you tried pulling those codes yet, if so, what are they?
Old Mar 30, 2004 | 04:50 PM
surgeon's Avatar
thx for the replies people
ok dont mean to be sarcastic to no one,this is the chain of events
1key in ignition dash lights up ,get the buzzer sound if u know what i mean
2.engine turns,no fire up then the smell of fuel,like flooded
3but engine check light never goes out
im hoping that it flooded and then try again tomorrow i will let you know what happens ? sorry to sound negative but ive had the car 3 years and have spent a fortune getting the body work done ,total respray,tinted glass,torque thrust 2 wheels,just to drive it to the M..O.T station to get it to pass (more money)
then go in home for a drink to come back and it wont start
thx everyone its much appreciated:hail:
Old Mar 30, 2004 | 04:57 PM
surgeon's Avatar
oh on another note,i disconnected the battery to clear the ecm codes,and i still get the same as i posted above
Old Mar 30, 2004 | 04:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No sarcasm taken, can understand the frustration. It would help if you could pull the trouble code from the computer, this would give us an idea of what could be possibly causing your problem. Are you familar with how to pull the trouble codes from the computer? Also, don't keep clearing the codes by disconnecting the battery, that will not solve your problem and since you have not listed any codes, it makes diagnosing your problem a little hard.
Old Mar 30, 2004 | 05:13 PM
surgeon's Avatar
no im not familiar with pulling the codes but would be willing to learn,but the thing i dont understand is why after re-setting the ecm it wont fire up?as in all codes have been cleared,so it starts afresh if u know what im saying
and correct me if im wrong the ecm checks the whole system prior to fireing?
Old Mar 30, 2004 | 05:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Ok Surgeon,
I have gone back and re-read through this entire post and I mis-read some of it and apologize for that. Your service engine light will come on when the key is turned to the "ON" position and will remain illuminated until the engine starts. The ECM won't check the entire system prior to firing. It will check the VATS system for the correct signal prior to enabling the starter enable relay and the fuel injectors. This system does not appear to be your problem at the moment. What size engine do you have in your car? Enclosed is a picture of the ALDL (assembly line diagnostic link) that is used to get trouble codes from the computer. You can use a paper clip to jumper pin "A" & "B" to read the codes. when you do this, the fan will come on which is normal. The first code is 12, the light will go "FLASH...FLASH FLASH" three times and if there are no other codes it will repeat this until the jumper is pulled. Code 12 is a normal code and means there is no pulse from the distributor. After code 12 flashes and other codes are present, they will then flash 3 times: example; code 32 will be "FLASH FLASH FLASH...FLASH FLASH"
Old Apr 2, 2004 | 06:58 PM
Vader's Avatar
Doc,
If you've disconnected battery power from the ECM, all error codes will have been erased, so your scan may not reveal much. Additionally, the SES light will not turn off until the engine is running, therefore, your light is acting normally.
You need to determine if you have strong spark at the plugs. Simply checking at the distributor will not eliminate all possible problems. Another thing to remember is that plugs that are soaked with fuel will not spark at all. The spark energy will be shunted (conducted to ground) through the saturated insulator. If your plugs are fuel fouled, remove and dry them, or replace them. You would need to dry them thoroughly, preferrably by heating, to drive all the fuel out of the insulators.
Once you have clean and dry spark plugs, crank the engine briefly to expel any accumulated fuel in the cylinders, then install the plugs and try again.
Old Apr 5, 2004 | 03:56 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Welcome to the boards surgeon, hope you have got the car started by now? Would love to see a pic of it!
Felix
Old Apr 5, 2004 | 06:42 PM
surgeon's Avatar
sorry for not replying sooner ,work and all that crap,
basically spoke to a few people,and they have given me the same answers as you people, thx to all who posted
basically because im no mechanic,not much i can do myself,no tools etc,and i would rather someone look at my car who knows whats what,and thats been organised today so hopefully it will be running again soon:hail:
pics i will post asap,like previously stated ive had the car 3 years,and havent done many miles in it just spending money on it as and when i can afford to,and its nearly finished,apart from the interior which is not bad but not like how i want it,but now i just want to drive it hence why i was pissed off when it passed it's mot then failed to start when i got it home
thx to everyone who took the time to help me,much appreciated
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
