Camaro dash lights
Car: 92 camaro 25th anniversary
Engine: 5.0
Transmission: Automatic
Camaro dash lights
Hi to all from sunny Shropshire.
I recently purchased a 92 Camaro 25th anniversary 5.0.
No regrets at all, ace car!, but need a bit of advice on a couple of dash lights that I don't understand and don't seem to be able to find any info and have been told that one is non original ?.
When ignition is first switched on, 2 lights come on briefly and then go out.
One says "infl rest" and the other says " exh temp " ( exhaust??) , the exh lamp is mounted on a blanking piece by the headlight switch and looks aftermarket.
Any advice would be appreciated, also, any UK parts suppliers would be helpful.
Cheers, Karl.
Cheers, Karl.
Last edited by KarlBurgess; Nov 13, 2013 at 05:06 PM. Reason: Unessasary information
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Re: Camaro dash lights
Ello Karl, nice car
INFL REST is the airbag light, EXH TEMP is indeed exhaust temperature, its connected to a sensor below the car in the exhaust. As both go out, they will be fine. My car is a 92 RS and also has an EXH TEMP light in the same place, which looks like an add on??? So it must be original? Although my car is far from standard, and has long since been disconnected. Parts? In all honesty, I find Summit or Jegs hard to beat. Ebay aswell. Very occasionally a UK supplier, usually too expensive.
Engine: 5.0
Hi and cheers for the info.
I had a feeling about the airbag, but as I am more used to classic Brit motors, I was not 100%. The exhaust one may appear obvious, but as it looks like a leftover bit from an air fix kit glued to the dashboard, it did confuse me a bit - pretty rubbish bit of plastic, not even on straight !.
All the best, Karl.
All the best, Karl.
Vintageracer
Aug 11, 2015 08:13 PM
