What size plugs do I need for the AIR holes in the exhaust manifolds?
Old Apr 14, 2002 | 10:47 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I had to replace my cat today. The old one turned into a can of rocks.
I figured while I was at it, I may as well rip out the AIR crap. No emissions testing here, but I wanted to retain the cat due to the $25,000 fine.
Anyway, I had done a search and saw a few people stated that the size needed to plug the holes in the manifolds was 3/8" NPT. So I took out the #2 flare, stuck a square headed steel plug I had laying around in there to verify the size I needed. I wanted brass plugs and plus hex heads for ease of installation.
Well not knowing much about flare fittings I didn't bother measuring the plug I had used. I took the plug with me to Menards to find some like it, yet brass and with hex heads. I went straight to the plugs and grabbed the first 3/8" one and held the steel plug next to it. It was the same. So I grabbed 8 of them and left.
When I had got home, I grabbed one, screwed it in, and it fit. Good, right? So I continued to remove the rest of the tubes. I went to install #4 and the plug was too big. I started scratching my head thinking "WTF?".
I checked the rest of them compared to the one that was too big, and they were all too big. Well I then verified that the stock flare bolts were all the same size. So finally I pulled out the dial calipers and found that the steel plug, as well as the stock flares were 5/16" Wish I had done that the first time.
Obviously the morons who packaged these things put a 5/16" plug in a 3/8" baggie. Well of course this was at 7:40pm and Menards closed at 7pm.
Now the problem really begins. The only sizes that Menards had were 1/4" and 1/8" (I had paid attention to that, at least). So now what? Obviously I need 5/16", and obviously they make them, so where do I get them? Anyone know?
This really puts the truth in the statement that Jim85Iroc has in his sig. "Weekend projects aren't"
I guess my other question is, are some cars 3/8" and some 5/16"? Or did I just get a bum deal?
Thanx in advance for any replies,
AJ
Old Apr 16, 2002 | 11:45 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I'm pretty sure mine were 1/2 pipe thread, i did it like a month ago I think I still have the bag I bought them in, I'll check when I get home
Old Apr 16, 2002 | 12:06 PM
MikeS's Avatar
Well, I've never done it myself, but can offer this to you...
http://www.engineersedge.com/pipe_external_thrd.htm
Maybe it will help, maybe not. Just a concerned thirdgenner doing what I can.
Old Apr 17, 2002 | 01:04 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
Mine were 1/4" if I remember right.
Mark
Old Apr 18, 2002 | 03:06 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
A buddy of mine did that 'mod' at my house last year and I think he used 1/4" NPT..... Not 100% positive though......
Old Apr 18, 2002 | 08:22 PM
AJ_92RS's Avatar
I should have posted this after I found out. Sorry. I finished it Mon. night.
The good guys at NAPA set me straight. You guys are right. They are 1/4". But something I learned is that with flare fittings, they measure the nuts/plugs by the pipe that they're on, not the nut itself. So when you buy 1/4" flare fittings or plugs, the thread pattern is actually larger than that, but not given a size to use as a guide. And they are not NPT or "fine" or "course" threads. They have there own little secret cut. I guess so you only use flare nuts on flared pipes.
AJ
toronto formula
Nov 10, 2015 06:17 AM
transaero
Aug 31, 2015 01:14 AM
wruiz
Aug 13, 2015 09:07 PM
timonator
Aug 11, 2015 09:56 PM
knight72
Aug 10, 2015 09:32 PM
