How does the computer know if the EGR valve is opening?
Car: 1986 IROC
Engine: 305 going to 355
I have looked through some schematics and the only wires I found were to the solenoid/swithing valve, but nothing to the EGR valve itself. The reason I am asking is because I got a code 53 and I am trying to figure out which of the 4 possible problems it would be. Just a note, I put direct vacuum onto the EGR valve and it did not open. I can move it with my fingers so I know it is bad, but how does the computer know?
Mark
Mark
Transmission: 4L80E/4L80E
It only knows about the solenoid. Not sure exactly what "high voltage at the EGR valve" means, unless it is high resistance or an open circuit that the ECM can see.
When you put the vacuum on the valve, was the engine running? Some valves are a "positive pressure" type, that needs the engine running in order to open when vacuum is applied. Wierd, but true.
Car: 1986 IROC
P.S. HEY five7! Some how I knew that I would get first response about this from you!
Mark
Zachattack0925
Aug 12, 2015 09:52 PM
