Need help getting the pass side manifold off URGENT
Old Apr 20, 2002 | 03:06 PM
TBI305Camaro's Avatar
ok ive gotten the drivers side manifold off and the header is on but i cant get the last back bolt off of the manifold...there is no AC or any of the emmission stuff in the way but i just cant get to the bolt...i have a swivel but the 14 and 15mm sockets i was using wont fit it i think the bolt is alittle messed up and plus it just wont fit...what can i do to get it off? its pissing me off thats the only one left and i cant get it i was hoping to finish today and get it to the exhaust shop but it looks like i wont be now....PLEASE HELP
Old Apr 23, 2002 | 09:24 PM
88GTAction's Avatar
I'm new to this but I think if you go to Sears they have some type of socket that suposedly grabs even stripped bolts.
Hopefully I was of some help to you
88GTAction
Old Apr 26, 2002 | 08:55 PM
91305z's Avatar
I just had the same problem and had better luck using a wrench. good luck
Old Apr 27, 2002 | 08:10 PM
92blackZ's Avatar
Car: 1992 Z28 camaro
Engine: 5.7
passenger side exhaust manifold
My son-in- law and I ran into that problem a couple of weeks ago.There is a factory metal tab that locks that bolt in.Bend the tabs back and you will be able to remove that bolt.We had a clearance problem also.We used a crow-foot wrench that was 3/8'' drive and finally got it out. GOOD LUCK!!!
Old Apr 30, 2002 | 05:49 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
he is right those little metal tabs can be a real pita when you cant see if it is off
one of my manifld bolts got rounded when i was doing the headerswap
and i hd to use a combo of a hammer and a pair of realy good vise grips(best toool i own)
hope this helps
Old May 1, 2002 | 11:24 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Exactly what I was going to say!
Old May 1, 2002 | 02:31 PM
chevyboy07 91's Avatar
man, EVERY SINGLE 3rd gen header install I did, I had the same D A M N problem w/ the same friggin bolt. Here is the trick....1st as the other said....that damn tab needs to be bent out. I just use a really long screwdriver and hammer to punch it out of the way. Secondly, you have to go from underneath and remove the y-pipe and use a 3/8" drive breaker bar w/ a regualr (short) socket. I forget the size it is, but its the same as the others.
This is a sure way to get it .......do the same for putting the header bolt back in. Mine were 3/8" bolts and I just used a wrench from underneath.
transaero
Aug 31, 2015 01:14 AM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
3rdgenparts
Aug 5, 2015 11:57 PM
