Passing e-check with no cats
Old Apr 22, 2002 | 03:20 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Is it possible? Easily? I was told that I had no cat from my car's previous owner because a straight-pipe had been welded on. Am I going to have to fix it before e-check or can I temporarily make it passable with gas additives or something? :-D
Old Apr 22, 2002 | 03:44 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Depends, do they do visual checks there, if so you'll fail, but if not you have a chance. Be sure to drive the car about 20 mins before you go, it helps clean the engine out a little, I've done it before and has lowered my #s.
Old Apr 22, 2002 | 03:45 PM
Z28DJP1987's Avatar
Not if they have a visual check for the presence of the Cat. I think you are SOL.
Old Apr 22, 2002 | 09:45 PM
Marshall89ws6's Avatar
yea they do visual..... dont try it just get cats even if you bolt them on just for the emmisions inspection
Old Apr 23, 2002 | 10:38 PM
KiLLJ0Y
Guest
Posts: n/a
do they check under the hood as well??? i have to get mine to emissions test as well... just wondering if they check under the hood.
Old Apr 24, 2002 | 12:12 PM
FyreLance's Avatar
I dunno, last time I e-checked (in an Escort, heh) they didn't seem to do any visual inspections.
I won't get in trouble if I don' t have the cats, right? They'll just not pass me?
Old Apr 24, 2002 | 03:06 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
echeck... you in ohio?
Anyways, when they did mine I dont even remember them checking for a cat, and Im sure they didnt do an underhood visual. The manifold I want to use doesnt have EGR, so I minus well pull off all the other smog stuff but the cat. I figure if I have the cat then lean it out before I go then I should pass.
Oh yea go in the dead of winter if you can, they'll want to get it done asap so they might not be as strict.
Old Apr 24, 2002 | 04:39 PM
Fast3rdGen's Avatar
the motor in my sig passed. i used my old edelbrock headers with the tubes removed and a new cat with flowmaster exhaust. i ran about 2 gallons of gas with 2 bottles of rubbing alcohol. i had .113 primary and secondary jets in my edelbrock 750 when i ran it through.
Old Apr 24, 2002 | 09:19 PM
KiLLJ0Y
Guest
Posts: n/a
so rubbing alcohol in the gas tank helps out that much hu?
Old Apr 28, 2002 | 05:24 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
We live in California. They check everything. Yes they look under your hood. They check your timing too. They look for all emissions equipment to be present, hooked up and functional. They also check for your catalytic converters. Its strict but its easy to pass if you havent been stupid and removed anything.
Old May 1, 2002 | 02:31 AM
az82z28's Avatar
wow..and i thought AZ was tough...
check your timing, too?? geez...they use to do a visual inspection for the cat here, but last 3 times i have taken cars through, they havent gotten their little mirrors out...but they did catch a broke EGR hose and failed my truck...had a gas cap fail another time. i use to have some cats off a 77 t-bird..they bolted onto the exhaust manifold...when i ran an old skylark i had, i just took off my normal exhaust pipes (with glasspacks) and bolted these right on the headers....then bolted mufflers to the cats...and had pipes run straight to the side of the car near the back wheel (cost me $40 for the 2 pipes with a slight bend) didnt sound as tough as the glasspacks, but was still mean.....AND it passed emissions..
LT1Formula
Oct 8, 2015 08:34 PM
racereese
Oct 3, 2015 03:46 PM
