help with headers
Old Apr 26, 2002 | 07:51 PM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
help with headers
i'm looking to buy some headers, but i'm not sure what kind is the best. i want something that'll give me the most hp. and what's the difference between shorty headers and regular ones. is one better than the other? thanks
Old Apr 26, 2002 | 08:40 PM
Tas's Avatar
Tas
depends what engine you have and if you have to smog it. If you have to smog it, SLPs are the best, if not, some longtubes are nice.
Old Apr 27, 2002 | 12:12 AM
92TPIZ28's Avatar
Engine: 355
i have the 305 and what does it mean to smog it? sorry for my lack of intelligence
Old Apr 27, 2002 | 01:03 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
SLP 1 5/8's.
Old Apr 27, 2002 | 02:21 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
He means if you have to keep your smog equipment in order to pass emissions tests. Shorties join the exhaust from both headers into one pipe under the passenger side of the car by a Y pipe. It then goes through the cat and down the passenger side, over the axle where (usually) it connects to a 1-in-2-out muffler and is split to both the right and left side at the rear of the car. Longtubes are associated with true duel exhaust... one pipe leading to the rear or sides of the car from each header. True duel is the best flowing, but is only really usefull for cars making over 350hp. I believe SLP shorties are the best shorties for our cars, but they are also the most expensive. I'd say Hooker Super Comp. and Edlebroch TES shorties are a close second... If you don't have to keep emmissions, then some longtubes are the answer (depending on your application). Run a true dual exhaust with an X pipe and you won't be dissappointed by the gains you can feel and hear!
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
