goign to sell hooker set up if i cant get rid of this cackle help!!!
Old Apr 30, 2002 | 10:43 PM
2ponchos's Avatar
got my new motor running today.. when i was reving it up a bit the muffler had a terrible cackle to it.. it did before to an extent and i lived with it but now i am starting to wondering i cant stand that!!! does anyone know how to get rid of that cakcle?? so if i cant figure it out i am selling it!! and going with true duals..
Old Apr 30, 2002 | 11:25 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You have a cat? probably normal to do loss of backpressure.
Old Apr 30, 2002 | 11:32 PM
2ponchos's Avatar
nope no cat..never had one lol cut it out as soon as i got home with the car.. i am still comptimplayting(SP) if i want to go with true duals or not.. if i do.. not saying i am but if i do do i have to run a cross over pipe or can i just run two pipes back??
Old May 1, 2002 | 12:03 AM
Car: 99 Formula
Axle/Gears: 342
I'd get an X or H pipe, No4N has an H I believe, that will improve performance.
Old May 1, 2002 | 12:24 AM
HrdRockA4305's Avatar
I doubt the crackling is from the muffler. You probably just hear it more now than you did before, so it increased the noticability of the symptom but didn't actually make the problem itself worse.
As far as I know the sound is caused by unburnt fuel being sucked through the system and igniting when it hits hot spots in the pipes. Cats make this less noticable because they burn it up plus dampen sound. Mike's LeMans (Camrs89) crackels and pops like hell... and he's got true duals with glasspacks. But its also running kinda rich, which would explain the extra fuel getting into the pipes.
Old May 1, 2002 | 02:18 AM
2ponchos's Avatar
NO4N is that acompany or a person on the board?? thanks and proabably you are right from the carb being to rich right now it might be making that crackling noise.. ill get it worked out but i have wanted to go duals for a while now so we will see
Old May 1, 2002 | 02:21 AM
Oh yeah, don't get me wrong, tru duals is way cool if you can pull it off.
Old May 1, 2002 | 02:30 AM
87GTA57L's Avatar
cackling?
could that be the sound of rotted baffles in the muffler?
what muff you got on her?
Old May 1, 2002 | 02:45 AM
2ponchos's Avatar
i have the hooker cat back system on it.. ive had it for less then a year.. hoped it woudlnt be something like worn out baffles but who knows.. if it is hooker will get a nice big letter and probably there muffler through a plate glass window
Old May 1, 2002 | 07:58 AM
Car: 99 Formula
Axle/Gears: 342
No4NJunk, member on the boards.
Old May 1, 2002 | 09:51 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Yeah, my LeMans as Dave stated, crackles when you let off the gas. Its cause I have a extremly worked q-jet on there that is a little much for the engine. Oh well, it will work just fine when the 455 gets dropped in.
Old May 1, 2002 | 10:59 AM
Someday.
Old May 1, 2002 | 12:03 PM
Camrs89's Avatar
yes, someday...I cant wait till then though. Paintence is the key.
Old May 2, 2002 | 06:09 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
I had the same problem that you ha dood. I thought I was running rich which i still might be. But what I did was take teh smog pump off and threw it on teh garage floor, turned the car back on revved that SOB and no more backfire or crackling. Try that. Taking off the smog pump only does more good than bad, unless you have emmissions testing. I plan to bolt it back on fo remmissions testing just in case.
Old May 2, 2002 | 09:17 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I've had the same thing two different times. The first time I was running too rich, the second was an exhaust leak where the manifold bolts to the head.
Frozer!!!
Jan 19, 2024 04:55 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
mcgarnicle
Aug 12, 2015 04:58 PM
SiCkRs
Aug 8, 2015 08:12 AM
