Plug Wires for my SLP Tri-Y's ???
Old May 3, 2002 | 08:38 PM
92GTA's Avatar
The factory AC Delco plug wires don't work too well with my SLP Tri-Y headers, the #3 plug wire is WAY to close and is going to burn.
What's the GM part number for the correct AC Delco plug wire that will work with these headers???? I am assuming that AC Delco does make them because they are headers that are available in the GM Performance Parts catalog.
Also are there special AC Delco plugs I should use too??? I will only use AC Delco parts on my car......
Old May 3, 2002 | 10:17 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Any time with headers it's a good idea to use some wire looms if you don't already have them. I burnt 3 wires that way, I also, bought some heat sleeving for added protection. Sorry I can't answer your question though.
Old May 3, 2002 | 10:37 PM
92GTA's Avatar
Thanks for the suggestions anyway. I still have the factory loom on there that another reason why I need factory size wire, and I also have the original SLP fire sleeving
Old May 3, 2002 | 10:50 PM
92GTA's Avatar
Ok, I found this page:
https://www.spoperformanceparts.com/...jhtml?CATID=16
It looks like the second set mentioned, part # 12043789 are exactly what I want but it says "Not for use with HEI distributors. Solid core wire may generate electrical interface; do not use with electric rev limiters and similar devices." Does this mean they will not work on my car or will they???????
Also, are these going to look exactly like the factory wires and are they going to be the same diameter???? They are only $28.83 too.
Thanks!
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 30, 2015 08:05 AM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
