Spark plugs wont fit!!!!
Old May 17, 2002 | 06:03 PM
ImportsRsloths's Avatar
New engine...........
World Products S/R Torquer heads.... straight angle plugs
SLP TRI-Y headers
The stock ac delco or any other "stock replacemant" brand will not fit on like four of the cylinders.... they hit the headers before you can even line them up to start screwing them in!!!! what can i do????
Old May 17, 2002 | 06:33 PM
89BlueTA's Avatar
The bosch platinum spark plugs are shorter than the AC delco's,
you can try those and see if they will fit.
nick
Old May 17, 2002 | 07:14 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would try the above mentioned. I used Accel shorty plugs once, but the tips keep coming loose, and happens to many others too.
Old May 19, 2002 | 03:21 PM
daverr's Avatar
headers
i have the same problem even with angled spark plugged heads.i adjusted the header clearance with the hammer.
dave
Old May 23, 2002 | 09:49 PM
Rice Eliminator's Avatar
I was going to say use the Accel shorty plugs like Mark said, but if the tips come loose. . . well, I've had no problems w/my Accel regular length U-grooves, anyway.
Old May 23, 2002 | 10:12 PM
Car: 99 Formula
Axle/Gears: 342
I love your signature.
Old May 25, 2002 | 11:31 PM
breathment's Avatar
i haven't had any problems with my accel shorty plugs.. except the autozone which wanted $160 for the package.. (they thought it was $20 per plug instead of $20 per package of plugs.) went to O'Reilys and got some from there..
you will probably have to get a shorty plug socket though. or make one like did cutting about half and inch off the end of one socket and just using a wrench to turn it.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
