for the exhaust professionals, please help
Old May 17, 2002 | 09:58 PM
canadiangta's Avatar
i have an 88 gta, 350 tpi, i want to rip off the whole air system, tubes and pump, but i think this has to **** up the o2 sensor. i will plug the headers with plugs know, but new headers will be on the way. but has anyone one with tpi done this with success, everyone says this will work but i would like a testomony. tell me all please
Old May 17, 2002 | 10:55 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
it wont effect your O2 sensor to the best of my knowledge, as i drove around for months w/o smog with my O2 sensor equipped car
Old May 18, 2002 | 02:44 AM
ORAY777's Avatar
You didn't get any codes or stuff like that?
Old May 18, 2002 | 11:10 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Mine's like that now. I ripped all of it off about 2-3wks ago. I've gotten no codes at all.
The diverter only flows air into the manifolds during startup/warmup time (aka Open loop). But the ECM also ignores all info from the O2 sensor during this time. It's set to do certain things for a certain length of time.
Once the car warms up (aka Closed loop), all the air from the smog pump is routed to the cat. The O2 sensor will not see any air from the pump until the car goes through Open Loop mode again.
BTW, it's easy as hell to take off. All you need are eight 1/4" flare plugs and a 1/4" pipe cap to use on the tube coming outta the cat. Otherwise you will hear an exhaust leak, which IMO sounds horrible. I already tried it without the cap.
And you can just tape off the wires that come outta the diverter. Otherwise they'll ground out and THAT may send a code to the computer or even short it out.
AJ
Old May 18, 2002 | 11:39 AM
no codes, no increase in power. a lot less crap in the engine bay
Old May 18, 2002 | 07:08 PM
82resto's Avatar
Haven't had any of that in a year, and my car is still running perfect every single day.. it's a real daily driver. The only difference I noticed (aside from the way less cluttered engine bay) was that it *seems* to take longer to warm up in the morning... But that could just be the car getting older, too.
Jon
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
