Got My New Exhaust In - Some Pieces For Sale
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i put in my headers (took 1.5 days) and had my ypipe modified by the exhaust shop i ported the collectors to make a smooth transition and cut off the part where the two pipes join and welded a 3"on there so that it is all 3" pipe. they welded in the straight pipe cat and ran 3" from the end of the cat to the race muffler under the trunk with a hideaway tailpipe(really hard to see unless real low or real far away)
i had bought dynomax part number 44063 ( summit part number WLK-44063) but didnt use it. this sells for over $80 new but i would like to sell it for $70. with this pipe you will need to buy dynomax part number 43248 (summit part number WLK-43248) which sells for $50. the you would have 3" mandrel bent pipe from the cat back, add your muffler and you are good to go.
thanks
brady
thanks
brady
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
1992 Trans Am
May 10, 2023 07:19 PM
MoJoe
Sep 24, 2015 09:12 PM
LT1Formula
Aug 20, 2015 09:36 PM
