exhaust bolt
exhaust bolt
having not long put a new exhaust system on my 87gta ithought it was blowing but on futher investigation i found that i have lost a bolt that holds on the manifold r/h side right at the rear of the engine block,are there any easy ways to put in a new one tips most welcome,it just looks like the most awkward place ever
thanks for the reply brodyscamaro,
on more investigation i find that the bolt in question has
sheared off roughly flush with the head and after speaking
to my mechanic he says to wait, because the labor
charges would be too much for the sake of one bolt.
wait as in putting on headers,cam change or some other
work,i would have a go myself but it's my daily driver and
if i screw up i'm f***ed no transport to work.
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
I take it the right hand side of the block is the driver side?? If so the top removel isn't that hard, if it is on the pass, disconect the battery and take out the starter. It will give you enough room. Just in case you decide to put in headers. As long as you are good with a wrench it isn't that hard.
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
